2g AWD fuel pump rewire
Nessuno
95
Jul 3, 2005
Lancaster, New York
Okay, here's the deal. I've tried searching the boards, and I also tried other research like VFAQ. I can't find any pictures of how to rewire the fuel pump harness on my awd tsi. The only thing I have found are for fwd 2g and awd 1g and the harnesses are different. Can anyone point me in the right direction? I just need some pictures, detailed instructions, something. I was in the middle of doing this yesterday when I realized that the harness looked different than the pictures I found.
really simple. on ## fuel pump connector when u take the cover off the assembly theres two heavier gauge black wires. the black wire with the grey stripes around it is the one ## to splice into. from the relay included put the ground wire to the car somewhere. i found a good ground behind the speaker panel. the big heavy cable goes to ## positive battery terminal and should have a 30amp fuse included inline. the other two connections on ## relay will be to connect to either end of the wire u sliced on the fuel pump connector
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
