2g AVC-R control, 1g wiring harness
Nick 4g63
40
Dec 2, 2002
does anybody have a diagram showing the wiring of the control unit? not the stuff apexi has online. i bought a 2g avc-r and the guy sent me a 1st gen avc-r harness with it (used stuff).....i know i have to fab 2 wires on it, which is easy, but wtf do i do with the rest?
you mean to connection to the ecu
or the harness for the solenoids and junk?
just use their diagram and solder directly.
ok, the skinny wires coming out of the control unit. I know what the purple, black, red, white, grey and orange wires are all for.
pink, brown, blue, yellow and green i have no clue as to where they go. I assume two of these are making their way to the boost control solenoid and the other 3 are going to the boost pressure sensor.
on my boost control solenoid i have a orange and a black wire. On my boost sensor i have a green, brown and blue wire. Hooking up the wires by color code does not appear as if they are working properly.
if some1 actually had a picture of the harness, control unit, sensor and boost solenoid all hooked up in one spot so i could see the color code transitions through the entire harness, it would be perfect...or if some kind soul would track down the wires for me, it would greatly be appreciated.
Resurrection!:hellyeah:
Ok I have a AVC-R too, and a SAFC as well. I had the SAFC working fine, decided to wirre in the AVC, and, well, crud. The SAFC light up on the buttons but not the screen, and the AVC doesn't do squat. Anyone have a wiring diagram or maybe a photo of how all this goes together? If I butcher my ECU harness anymore I'm going to be screwed LOL.
  • Wanted 6 bolt NT water pipe
    • chrisman287
