1G Wiring Harness
socjdqcer
46
Nov 9, 2010
Chicago, Illinois
Hey all, im too new of a member to post this in the classifieds, so ill just post it here. Im doing a 4G63 swap into my 88 Chrysler Conquest TSI. Anyways, everything is running smoothly, but i need a engine wiring harness. the idiot i got the motor from said it would come with the harness, and it did, except he CUT it at the firewall, like a redneck. so its useless. I have gone to all my junk yards and cant even find a dsm. so my question is, can i use a NON-TURBOED dsm harness or does it have to be a Turboed harness? Also is there a good place to find them online? Ebay has a few, but they only say whether they are off of a manual or a auto. anyways, thanks
jared
Yes there is a difference but you can modify the N/A harness to work. You will still need a turbo ECU though.
Check out this tech article that mavisky wrote: http://www.dsmtuners.com/forums/articles-engine-fuel/37019-installing-turbo-4g63-into-nt-4g63.html
what you'll need to wire in:
7th wire from mas - the 7th wire from the mas needs to be run back to pin number 6
knock sensor - one wire can be grounded to the engine bay somehow, the other white wire needs to be run back to pin number 9 on the ecu.
wastegate solenoid - one wire here will be grounded, the other returns to the ecu at pin number 105
injector resistance pack - this is the most dificult. i'll let the following pictures describe it rather than trying to explain it in text. if you have any questions just ask.
And here is a tech article by TimG on how to wire the injector resister pack on a 1g n/t harness: http://www.dsmtuners.com/forums/articles-electrical-wiring/174314-injector-resistor-pack-wiring-1g-n-t-turbo-conversion.html
Hope this helps!
