2g 7 bolt
kendrick
Oct 26, 2014
gainesville, Georgia
alright i know its a downgrade but im planning on switching back to my original 7 bolt motor what all would i have to do in order to make it a easy swap alot of people say plug an play but since it was a six bolt swap previous owner cut alot of the wires.. so my question is can i use the 1g cas an put the 7 bolt back in with no problems or do i need to rewire my whole harness an also he cutt the knock sensor will i need that as well thanks
U can use the cas only if you swap the cam with it... Bc some 7 bolts have the cam sensor and it just has a screw in the end of the pick up and the knock sensor is 2 wires shouldn't be hard to put back.
I am in a lil pickle myself trying to finish a 7bolt head 6bolt block setup for my auto...now I have to reach 30 posts so I can ask more detailed questions LOL
