2g 6 bolt
Jaysgsx14
Nov 12, 2003
Glastonbury, Connecticut
How do i do it what do i need to change(engine mount) wiring anyone know how to do it????
It's not very hard to do. www.magnusmotorsports.com has a tech article on it. It is damn near a step-by-step install guide. I've also done the swap. All it takes is confidence, some mechanical know-how, and you need to know what has to be done in order for it to work like plug wire/coil pack changes, CAS wiring, and sensors that need to be changed out like coolant temp and knock. Look through the guide and other resources on the net before you jump into the pot.
Check out SLOWBOY Racing they have a kit for sale that come with everthing you need to do the swap :dsm:
