2G 14B tuning path
gorf
673
16
Dec 13, 2004
Chapel hill, North Carolina
OK not sure where to go next. See my profile for mods. I am running into fuel cut at about 6k when I turn boost up over about 16lbs.
I have a 190 walbro but have not installed it yet.
Also have not recently done a boost test, will do that before anything else.
What is the best route for me to follow? My car has 130k so I am not real interested in spending a lot of $$$, But I do want to squeeze out as much as I can out of my 14b.
I can go logger/safc for about $350- $400 or ECU with a chip for about the same $$$ but not have any logging capability.
I really would like the easiest solution that is going to allow me turn the boost up close to 20 lbs.
In the long run, if I change my mind and want to go to an evo III which solution would match the evo III better?
Should I go to 550 injectors?
Good source?
CanadianTSi said:
A front mount and some 650's with a chipped EPROM would work well.
650's??? Wouldn't that be way overkill for a 14b???
