2900ACT Street disk PROBLEM !?!?!?
Pursuit
326
Apr 3, 2007
las vegas, Nevada
I have 2900 act pp clutch with street disk, my idle it's 2000rpm and some times when i push the clutch the RPM go down and the engine turns off.
What can be the problem !?
I have brand new engine on 200 miles,maf-t,dsm link,75mm bbk tb,288 bc cams,wiseco 9.1 cr pistons. the engine working very good not smoking or bad noise, i break in the engine with 20w50 castrol gtx.
HELP :sosad:
Check for crankshaft endplay. You may be crank-walking the thrust bearing on the main journal.
A 2900 pressure plate is way overkill and is not a good choice due to its extremely high pedal pressure that puts a hellofalot of thrust load on the crank. Check your oil pressure as well.
Are you sure that you have the clutch properly installed and properly adjusted?
HELP :sosad:
I have a PTT and mine does that on COLD starts.
However,
As twicks said, that clutch is just stupid heavy and you probably dont have it installed right.
