255 fuel pump??
1g4g63pwr
50
Dec 26, 2005
brooklyn, New York
Hey guys if im running stock is it a good idea to get a 255 walbro fuel pump? if i do put it in what will be the aftercause of it?
I would recommend doing the rewire though. It's pretty cheap to do and helps the pump out a bit. :thumb:
Yes it would over run your fpr making your base fuel pressure iratic and causing your car to bog down. It would be a waste of a pump and money. At this time for you, I would not be woried about my fuel delevery.:talon:
If you are not going to go into hardcore DSm get a 190lph/550cc/Fuel controller/No AFPR.... (an IDEAl set up.)
If you wan a lot of Fuel to be safe: 255/AFPR/Injectors/fuel controller/etc....
Fuel pump Info
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
