Resolved 20g turbo identification
Andrews93gsx
May 26, 2010
Pardeeville, Wisconsin
Hello I was wondering if someone can help me identify this 20g, Please see the attached pics, it came with a 7cm exhaust housing. Thanks
kinda looks like a 2.4 inlet 20g, a buschur 20g style. Also you could measure the turbine wheel for it's specs, Could be a 16g turbine wheel (still good because quick spool with more airflow from comp wheel). You more than likely have a hybrid 20g like a lot (myself included) run. I've logged 45.5lb/min on stock cams and block in my 1g awd at 23psi
Take a better picture of the serial number.
Alternately.... Taken from http://www.columbusdsm.com/forum/showthread.php?p=150406
49178-01010 - 14b
49178-01520 - Small 16G
49178-01420 - Big 16G
49178-01470 - EVO III 16G
49179-05200 - TD06 - 16G
49178-05200 - TD05H -16g (galant)
49178-05400 - TD05H -20G
49179-05400 - TD06H -20G
49178-05400 - TD05H -20G what did this turbo come off and what manifold pairs with it
