Ludachris
Founder & Zookeeper
- 8,937
- 4,919
- Nov 12, 2001
Newcastle,
California
Email your submissions to Login to see the hidden content by October 15th, 2025 with your DSMtuners username in the subject.
Please follow these instructions:
1. Only send me 1-3 high resolution photos of a DSM (or 4G63-powered vehicle) that you own, and you must own the rights to the photo or have the right to grant us permission to use it for this purpose (without watermarks if possible, or at least small ones). Photos from DSM events are fine, so long as you took the photos or have the rights to use them.
2. Please include your username on DSMtuners in the email subject. If submitting photos of your own DSM, please have a Vehicle Profile for your DSM here on DSMtuners.
If the photo is of a car you saw at the Shootout or another event, try and get the owner to log in here and submit additional photos - maybe they have a better shot of their car we can use.
3. Each photo you submit must be at least 2500 pixels wide, minimum - this is critical. If the photo is less than 2500 pixels wide then it will not print well and it will not be considered. If you're unsure, check the Properties of the file when you copy it to your computer. Attempts to upsize a small photo usually always results in poor print quality. If using a phone, set your camera settings to its highest setting when taking photos. Print-worthy photos are typically measured in MB (megabytes). If the file size of your image is measured in KB (kilobytes) it's likely too small.
4. Please, no photoshopped pics. If you need to cut out the license plate, that's fine, but I can do that for you. But please don't add special effects to the photo.
5. It's fine to have more than one DSM in the photo, but if your car is in the photo, specify which one it is.
6. Please only submit photos that are in landscape view instead of portrait. The calendar pages are printed in landscape view, so this will maximize the image on the page. Just in case you're unsure which is which, this image should help.
When you email your photos, include the photo attachments and the following information:
- Your full name
- Your DSMtuners username
- Year/make/model
- Any notable accomplishments/achievements with the car (records, championships, etc)
- Attach your photos
ENCOURAGE OTHER DSMers ON SOSHUL MEDIUH TO SUBMIT PHOTOS TOO!
For those who want one of the past calendars with 2026 dates, you can order one of those here:
https://www.dsmtuners.com/pages/dsm-calendars/
- Your full name
- Year/make/model
