20 psi car is set at with no boost controller
If the wastegate is set to 20psi you cant go below that.
Where did the wastegate actuator come from?
Sometimes you can shorten the actuator arm I believe or lengthen it to adjust boost, but buy a manual controller and turn it down
You cant go below what the wastegate is set at. If its a 20psi wastegate actuator, its 20psi or above. You cant go down.
some kind of big 16g and a full 3 inch i believe
From that alone I can almost for sure tell you that the car is not set to 20psi...A 16g and 3 inch exhaust lead to boost creep..Say the wastegate is 12 psi well at WOT the turbo will build the 12psi and then creep to a higher number..Resulting in the 20psi you were describing..
http://www.dsmtuners.com/forums/art...oler/186525-how-cure-boost-creep-porting.html
http://www.dsmtuners.com/forums/art...rcooler/96678-boost-spike-vs-boost-creep.html
http://www.dsmtuners.com/forums/art...564-how-port-turbo-exhaust-housing-video.html
http://www.dsmtuners.com/forums/art...boost-creep-modified-wga-peepers-mod-how.html
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
