2 piston calipers w/banjo fitting on a 1G
GSX_Dan
138
4
Jun 27, 2004
Chicago, Illinois
Hi, I have purchased a pair of front 2nd gen AWD brakes for my '90 AWD not knowing the lines would be different. I haven't tried to bolt these up yet, but they came with the mounting brackets so it should be no problem. Now the problem is these new calipers accept banjo fittings and my stock lines are not banjo type. I was thinking about getting SS lines anyways, but for what year should I order? Simply 2nd gen? Are they all banjo? I'm a little confused at this point because the FAQ's say only 95's came with banjos but I ordered calipers for a '98. Would there be a problem with getting SS lines for a 2G w/banjos or will they not bolt up to my car's hard lines? Any input would be appreciated, thanks.
If you have SS hoses now then have someone change the ends to banjos for you who knows how to do it.
If you strike out and need some hoses made like this let me know. You need a hybrid 1-2G from the sound of it. Four hoses of the 1G but with banjos on them if I read it right.
That's odd. The twin-piston calipers I picked off a '96 Diamante LS seem to accept the same kinds of lines as my stock single-piston calipers.
I ordered a set of lines from RRE not to long ago, either.
I will try to go find a place here in the city that could make me some custom SS lines but if it doens't work out I'll have to take you up on that offer. Thanks.
