2 piston calipers on 1g
slider85
469
May 21, 2004
Langley,
which models have the two-piston calipers? GSX and AWD, right? Which year two-piston calipers will work on my 93 Laser NA? Also, would those calipers be close to the performance of the Baer Kit if I put SS lines in as well?
93^ awd, galant vr4, stealth/3kgt, and 95^ diamante had the same dual piston calipers. You will need the calipers, caliper mounting brackets, and rotors. The galant rotors wont work because if I remember correctly, they are for 4 lug cars.
Im not positive but almost sure the Baer kit will be better with the larger rotors. Anyone is welcome to chime in if Im wrong.
what is the difference in rotors? I just got new front rotors about six months ago.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
