MarkAngelo05
- 201
- 2
- Nov 7, 2006
Pearl City,
Hawaii
Hi!
This is what I'm experiencing. 10:1 A/F ratio chip, Stock base fuel pressure/regulator, FIC 650cc injectors (285 uS Deadtime settings on chip), 18 to 20 psi boost.
Okay, well, I keep having to add around 13- 18% positive on the AFC to achieve a 10.5:1 Air Fuel Ratio. Jeff said that without AFC settings, I should be close to the target air fuel ratio, but it's not working out right. The chip has fuel maps for 10:1 A/F Ratio target, but it is never close.
With 0% AFC corrections, I'm at around 12.5:1 Air Fuel Ratio.
I have an EVO IX Fuel pump, rewire kit, stock FPR. I do not know what the problem could be. I thought it may have been the fuel pump, but my air fuel ratio does not drop with more boost.
The reason why I would like find out what is wrong, is so I can use less AFC corrections, so my timing/mas air signal is not altered as much by the increase AFC correction %.
I am using a PLX DM-5 Wideband setup. My idle A/F Ratio is around 14.7:1 to 15:1
What else should I check? Could I have a bad MAS... Could I have a bad front o2 sensor, but I don't think it matters at WOT. A boost leak would make me run richer.. I'm running a stock 2G VIRGIN mass, with the stock intake system, all tightened up..
I have bybassed the FPR solenoid, still the same symptoms.. Could it be that my EVOIX pump is just not cutting it?? Even at 15PSI, I'm at 12.5:1 AF ratio WOT 0% AFC corrections..
Thank you all for your help in advance...
