92eagleTSI
- 133
- 2
- Feb 26, 2005
Columbus,
Ohio
I'm using the plx 300 and noticed my a/f ratio isn't very steady. Whether your just cruising or in it a little or wide open it will jump about .5-1.0 either direction like it's cycling. This isn't normal right? It should be pretty steady correct? It is like that even on the narrowband so its not the wideband. I think everything has been checked except resistor pack, can this where out? Also I had painted my ex. manifold before and noticed that after all the paint burnt off that there was still paint around the #1 & #2 runners at the head flange, it actually tappered off from 1 to 4 runners like 4 hotter than 3, 3 hotter than 2, and 2 hotter than 1. Also has anyone ever had their open wastegate trigger the knock sensor? Sorry for the lengthy post I figured i'd get it all out at once.
