2.4LR Build compression Ratio Questions
boostback
51
Aug 4, 2013
minot, North Dakota
So as title states I’m building a 2.4 long rod with a 4g63 6bolt head. I have a good g4cs block and crank currently at the machine shop. Main concern I have is a lot I’ve been seeing on other threads is about ending up with a crazy high compression ratio because of the 4g63 head. The pistons I’m currently looking at are the wiesco 1400HD 8.5:1 that are listed for the 2.4 build but don’t want to get it done and have issues. If anyone has any part numbers from a personal build or any info it is greatly appreciated thank you. Also because it always gets brought up I have a turbo to support a decent bit of power a HX40 Super and and am about to send my trans off to jacks for a full dog box gear set.
