2.4 liter spark plug
Cesarlcase
261
5
Dec 29, 2009
lynbrook, New York
I have a 2.4 7 bolt, was just wondering should I still gap my new plugs to .28 or what?
He probably seen this from someone else posting recently about .04x garbage.. Can we edit some of these old threads giving bad information? The same questions get asked repeatedly..
If it's turbo'd, then yes. You'd want .028"
Oh okay, I figured with the bigger motor ,the gap should probably change. Another question, if the gap is to big, can that effect the battery voltage? for instance, if I turn the head light on and the volts drop from 13.7 to like 12.9 and only increase slightly with rpm, can that be a cause of to wide a gap? Thanks again
