snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
If you're positive they're from that head, then you should be fine. They're labeled so that you can put them back in the correct order.
blazebolt, didn't you give me some mumbo jumbo about if the caps were taken out of order i had to get it remachined?
the best i got now is he kept them and the rockers in two bags marked intake and exhaust side, along with bolts ect.
you are saying that is enough? if so i can head to the machine shop now right?
good day!
What external oil cooler do you plan on getting?
You call those parts clean?!?! You need them media blasted/powdercoated
If you need give me a call Phil.Well my wiseco are .020 over but the research I been doing says I am supposed to check for wall clearance depending on my set up, and the piston rings are gapped a special way ect.
I don't know what I'm talking about much but I would sure like to. Do I need to know anything besides the size of the piston? They will know everything else? Do I need to buy a caliper to double check they do it right, or is that just something you would do for a shop that may not do only dsm blocks?
I am not sure how precise things like this have to be, and I don't want to build my engine twice too soon
I still can't find good info on runing a kiggly girdle or not, but what I can find is that it CAN'T hurt anything, and it CAN help, so 150 dollar insurance, why not... I guess... Already spending thousands, why not a 150 dollar peace of mind I guess.
