2.4 Hx40cf spyder
import solutions
264
173
Apr 27, 2013
colimA, Texas
Hi to all im from mexico
This is my setup and my car Weights 2800lbs, in the road of 10s I hope can do it possible
Dsm spyder
Weight reductions:
Race seats
Manual Windows conversion
No air bag
Aftermarket Steering wheel
No a/c
No heater
Cf/fg dash board
Cf doors
Cf hood
Cf headlight deletes
Cf central tail light
Cf csl carbon/kevlar hatch
Spare tire Spot deleted
10 gallon fuel tank
Trunk gutted
No speakers
No insulation
Manual mirrors
Rear impact bar deleted
Front impact bar deleted
No emisión stuff
No convertible top motors
No wipers stuff
Fuel
6 an feed hose
6an return hose
Aeromotive a1000 afpr
2x intank 320lhp aem pumps
Obx fuel rail
Upgraded fuel filter
2200cc High z injectors
Snow performance stg 2 water/meth injection
Electrical
Cas conversion
High z wiring conversion
Saturn alternator
Engine wiring Rewired /New Fuse relay panel for all car stuff
Battery relocation
0awg wire for batery
Alternator heater shield
Gates blue belt
Exhaust
3" exhaust
No cat
Xs t3 Turbo mánifold
3" V band downpipe
Dp wrapped
Manifold wrapedd
Turbo
Hx40
6 blade
6064
Bep t3. 70
Extreme psi oíl feed line
Custom 12 an oíl return line
Fp 4" intake
2.5 intercooler piping
Q50 tial
38mm external tial wastegate
External dump pipe
Mac boost solenoid
Engine
2.4
.20 overbored
Wiseco 8:8
Manley rods
100mm oem crank
Acl race bearings
Arp L19 head studs
Bs deleted
Arp Main studs
Cometíc head gasket
6bolt head
Drag smim
Q45 intake
Fluidamper crank pulley
Adjustable cam gears
280 cams
Bc springs
Retainers
3g lifters
Kiggly hla
Gates blue timing bel
Ble sólid tensioner
8an Vc vented
Catch can system
Prothane mounts
Aluminum Vacuum Manifold
Sílicone vacuum hoses
Greedy magnétic pan bolt
Ignition
Bp8es
10mm Spare wires
Oem coils
Cooling
Aluminum radiator
12" spal fan
Mishimoto radiador cap
Steering
Depowered steering
Power Steering system deleted
Fuel managment
Ecmlink v3
Gauges
Innovate lc2
Oíl Trans temp
Engine oil pressure
COOlant temp
Fuel level
Vacuum gauge
Autometer boost gauge
Voltmeter
Tachmeter
Brakes
4g brake disc
Audi vacuum pump
Awd conversion
Transmisión
Auto w4a33
Kiggly 6 clutches front conversion
Rebuilt
4500 stall converter
Translab shift kit
Jb front diff grip
Central diff welded
Hygard atf
Tru COOL cooler
8" cooler fan
Forced four shift box
Steering wheel shift buttons
Lsd Rear diff
Suspensión
Tein full coilovers
Energy suspensión total bushing kit
Strut bars
Extras
Zex nitrous kit 75hp jets
