2.4 G4CS Automatic 1g Gsx build
velocitysport31
160
Feb 19, 2009
Oak Hills, California
Whats up guys just putting the finishing touches on my new setup. Here is whats done so far.
-G4CS 2.4
-Eagle Wiesco's
-Arp mains and head studs
-clevite 77 bearings
-Fluid dampner
-ported head
-Fp2 Cams
-Auto trans
-reworked valve bodies
-shift kit
-4k stall
-Dsmlink V3
-880 injectors
-walbro 255
-ETS Race Front mount
Couple of things i need to still figure out
1. Afpr regulator setup
1. Turbo setup
-Any suggestions, I have a new bastard 20g I can use
Will I be able to make some good hp with the Bastard 20g ?
The turbo will put you into the 11s with a good tune. I would look into something in the 60-62mm range, unless your thinking bigger then that.
hx40-3586-6262-s362 or bigger 4088 or 94-s366-t67 etc.
You got a 2.4 so it will make it a pretty nasty street killer with the smaller of the bunch.
