1ST Log and got some Knock
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
Got my datalogger today and I did a run. I hit 5 maybe once or twice on it and 1 a couple other times. Up in the higher rpm range. What usually causes this? Car seems like a loss of power. What do you do to fix the knock?
Yes, boost level info would help. Before you begin logging, i would recommend checking your base timing to see if it is in spec (+5). Any fuel control? If you are knocking, you are more than likely running a little on the lean side. Do you have any other mods besides what is in your profile?
By the way, where are you in Iowa?
Im running stock wastegate with bcs removed. In waterloo. Whats in my profile plus its a 6bolt now. With balance shafts removed, light flywheel and clutch
Do you have an aftermarket boost guage? I bet you $$ for starters you are experiencing boost creep with that exhaust. ECU is pulling timing in higher RPM's (hence, why it seems like it looses power in upper RPM band).
Time for a fuel pump!
As long as you still run the stock injectors, you will not need any fuel management regardless of a bigger fuel pump.
