1st Log
whiteflash
480
Jun 16, 2006
Ridgefield, Washington
How does it look?
Mods:
3" Cat back exhaust, Intake, Autometer boost/AF guages, MBC (13 psi on t-25) , RRE UICP, 1G bov, Exedy Stage 1 clutch.
1st Column: Calculated load value
2nd: Engine RPM
3rd: Ignition timing advance
4th: Oxygen sensor 1
5th: Oxygen Sensor 2
19 2199 31 180 720
46 2382 12 920 920
80 2820 2 940 960
100 3535 6 960 960
100 4304 7 960 960
100 5046 11 960 960
96 5757 17 960 980
89 6351 18 860 920
21 5437 34 600 880
15 3828 23 60 880
15 2601 21 0 120
18 1460 15 20 0
20 992 9 940 640
If this looks good I'm going to log a run at 15 psi. thanks guys
Well first off, you dont need to log the first and last things you have on there. Secondly theres not enough points to tell if your running good. Take off the two I mentioned and re-do your log. From what I can tell though your running a little rich from 2800-5700. Then at 6300 it looks a little lean. But again it's hard to tell anything with that few of points.
Also, what gear are you doing this in, 3rd gear from 3-7k would be ideal.
i did the log in 2nd
ok, the hard part is finding the right road to do it.
