1st Log , comments?..
big_d
718
7
Nov 29, 2005
Columbus, Indiana
Here's the first log i took of my 93 Talon N/T......Just seeing how everything looks(car does have 156,000 miles on original motor):p Tell me what you think..
ERPM TIMA EGRT O2-R BARO ISC TPS KNCK INJP
1437.50rpm 21.00º -27.72ºC 0.55V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.41V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.29V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.45V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.66V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.70V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -29.22ºC 0.58V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 20.00º -27.72ºC 0.43V 0.93bar 27 8.63% 0 3.07ms
1406.25rpm 21.00º -27.72ºC 0.25V 0.93bar 27 8.63% 0 3.07ms
1437.50rpm 21.00º -27.72ºC 0.20V 0.93bar 27 8.63% 0 3.07ms
1406.25rpm 21.00º -27.72ºC 0.27V 0.93bar 27 9.02% 0 3.33ms
1437.50rpm 21.00º -27.72ºC 0.53V 0.93bar 32 12.94% 0 4.86ms
1500.00rpm 22.00º -27.72ºC 0.57V 0.93bar 39 14.90% 0 6.40ms
1562.50rpm 18.00º -27.72ºC 0.62V 0.93bar 41 15.29% 0 6.14ms
1593.75rpm 19.00º -29.22ºC 0.64V 0.93bar 42 15.69% 0 6.14ms
1656.25rpm 20.00º -27.72ºC 0.49V 0.93bar 42 16.08% 0 6.14ms
1750.00rpm 21.00º -27.72ºC 0.27V 0.93bar 56 21.57% 0 7.94ms
1812.50rpm 13.00º -27.72ºC 0.18V 0.93bar 59 21.57% 0 7.94ms
1937.50rpm 15.00º -27.72ºC 0.14V 0.93bar 60 21.96% 0 7.94ms
2093.75rpm 15.00º -27.72ºC 0.18V 0.93bar 73 89.80% 0 11.52ms
2406.25rpm 12.00º -27.72ºC 0.78V 0.93bar 98 93.73% 0 11.52ms
2375.00rpm 16.00º -27.72ºC 0.86V 0.93bar 98 94.12% 0 11.26ms
2531.25rpm 15.00º -27.72ºC 0.86V 0.93bar 98 94.12% 0 11.52ms
2718.75rpm 17.00º -27.72ºC 0.86V 0.93bar 98 94.51% 0 11.26ms
2906.25rpm 18.00º -27.72ºC 0.86V 0.93bar 98 94.51% 0 11.26ms
3093.75rpm 20.00º -27.72ºC 0.86V 0.93bar 98 94.90% 0 11.26ms
3250.00rpm 21.00º -27.72ºC 0.86V 0.93bar 98 94.90% 0 11.01ms
3437.50rpm 23.00º -27.72ºC 0.86V 0.93bar 98 95.29% 0 11.01ms
3593.75rpm 23.00º -27.72ºC 0.86V 0.93bar 98 95.29% 0 11.26ms
3750.00rpm 24.00º -29.22ºC 0.88V 0.93bar 98 95.69% 0 11.78ms
3937.50rpm 23.00º -27.72ºC 0.88V 0.93bar 98 95.69% 0 11.78ms
4093.75rpm 23.00º -27.72ºC 0.88V 0.93bar 98 95.69% 0 12.29ms
4343.75rpm 22.00º -29.22ºC 0.88V 0.93bar 98 96.08% 0 12.54ms
4500.00rpm 22.00º -27.72ºC 0.88V 0.93bar 98 96.47% 0 13.06ms
4750.00rpm 21.00º -27.72ºC 0.88V 0.93bar 98 96.47% 0 13.31ms
4906.25rpm 20.00º -27.72ºC 0.88V 0.93bar 98 96.86% 0 13.57ms
5093.75rpm 21.00º -27.72ºC 0.88V 0.93bar 98 96.86% 0 13.06ms
5343.75rpm 22.00º -29.22ºC 0.88V 0.93bar 98 97.25% 0 13.31ms
5531.25rpm 22.00º -29.22ºC 0.90V 0.93bar 98 97.65% 0 13.31ms
5687.50rpm 23.00º -29.22ºC 0.90V 0.93bar 98 97.65% 0 13.57ms
5781.25rpm 23.00º -27.72ºC 0.90V 0.93bar 98 97.65% 0 13.31ms
5968.75rpm 24.00º -29.22ºC 0.90V 0.93bar 98 97.65% 0 13.57ms
6093.75rpm 24.00º -29.22ºC 0.92V 0.93bar 98 97.65% 0 13.82ms
6125.00rpm 24.00º -27.72ºC 0.92V 0.93bar 96 3.92% 0 1.54ms
I think it looks pretty damn good, what turbo/psi are you running and what are you using to adjust fuel, etc.
The car is N/T, so no 0 psi is as good as its gonna get for him right now.
I hadn't noticed the tps, but I'm with spyderturbo007, that number should to the high 90%'s and stay there. That jumping around is a little weird. Maybe a bad TPS, or maybe just a jumpy right foot :thumb: .
my bad, thought you did a turbo swap... the TPS shouldn't move around, so it could be giving bad output, try some more runs to see if you can replicate what is going on.
