1ga motor into 1gb car, lots of questions
carl5463729
169
3
Jul 21, 2004
Lancaster, New York
i have a 90 gsx and a 92 tsi awd shell. so i took the motor out of the 90 and put it into the 92. i have a couple questions, any help is appreciated. (1) I dont think the 92 has cruise control which from the motor in the 90 it does, so can i just leave it disconnected and it will work fine because i have a sensor coming off of the cruise control. (2) i put on the 92 coil pack onto the motor, i connected the correct sensor to it, but the thing is the 90 coil pack that i had on the motor is still connected to the 92 harness, so did i plug in the old cas into the wrong spot and something else goes there? (3) i bought the evap elimination plate a long time ago but i have lost it, i heard you can just disconnect one line and it turns it off anyways, do u know which line? any help is appreciated, thanks
I don't know about the other stuff, but if you have the non cruise control cable, it will work fine. If you are trying to use the 90 cruise control cable and box in the 92 then you wont be able to use it. just use the throttle cable that is in the 92, and if it doesn't have one, you can get them from Extremepsi.com for cheap.
i just have the 90 cruise control with the box, i dont care if i cant use the cruise control but i want to get this done now, and i dont have the 92 throttle line, so if i just left the 90 disconnected it will still work right?
