1ga fixed headlights
manifestmessiah
147
Mar 26, 2011
Ravenswood, West Virginia
Okay, I've done some research and so far I haven't came up with anything. I want to do away with the pop-ups and turn the lenses into actual headlamps. Is this possible, and what would I need to do in order to convert them? I want to keep the same look but have them as functional lamps. Any help is greatly appreciated.
I don't quite get want your trying to do...
So you don't want to swap to 1gb lights?
And your wanting to make it that your lights are on when the pop-ups are down and therefore shine out the front lenses?
I'll try to be as clear as possible to avoid further confusion.
I don't want to swap over to 1gb
I don't want my pop-ups lowered to shine through the lenses
I do want to get rid of the pop-up assembly all together
I do want to convert the stock lenses into a functional headlight assembly
Hopefully this helps you guys understand what I'm asking.
I have read/heard of attempt to mold the 93-97 rx-7 lights into out housings. It would require cutting, and custom fabrication. I think it would be an interesting and unique look
take a look at this link:
http://www.dsmtuners.com/forums/appearance-interior-exterior/207412-1ga-hid-projectors.html
Jose (ArcticTSi) did exactly what you are wanting to do. ARCTIC RACING
