1g to 2g swap
gsxkid
39
Aug 14, 2004
Billerica, Massachusetts
I have been searching but i cant find anything that says it is possible to put a 1g gsx into a 2g thats not awd. Say maybe a 2g gs will the motor mounts line up or no.Cause im in the process of rebuilding the gsx motor and its already out so i was thinkin of putting it back into a 2g :confused:
Thanks for reply ive been on that site it doesnt really give me the answer im lookin for. But the motor mounts will line up though?And will i be able to hook up the awd or will i have to have fwd. Thanks for any replys
If you're planning on installing a 1G engine and drivetrain into a 2G FWD platform, you are going to be in for a hell of a project. To the best of my knowledge, the 1G AWD transmission mounts are different than the AWD 2G, much less the FWD versions. If you are just putting the motor from a 1G into a 2G, it should be much less complicated, but the motor mounts should line up correctly, you will just have to do some trimming as per that Vfaq article.
if I read it right you want to put a 4g63 into a 2g gs... nothing lines up and there is a whole lot of shit you would have to do.... do some research on non turbo to turbo swap forums....
its possible but it takes time and money...
check out evilboost.com if the site is up yet
