1G Throttle body on 2g!!???
talonkid
43
Feb 22, 2004
el paso, Texas
i have heard of people swapping the 1g throttle body for the stock 2g one because its bigger....now im wondering what do i need to do that? like just the throttle body or is there any sensors or anything i might need...and is it plug and play or any modifications needed??? please help me out thanks :confused:
The important part is to search before you ask. Anywaz, what matters most is the IAC on the TB. Certain ones can't be used. Besides that, gasket.
It would be a good idea to replace the shaft seals and the BISS screw o-ring before the install. They are most likely old and worn out and will leak under boost.
There is a tech article on the seal install, it shows how to replace the seals on a 90 Throttle body, but the 91-94 install is basically the same.
all dsm iacs are the same.
when doing a swap to a 2g you must retain your 2g tps. when swapping it over you must set it properly so you get the right idle. this can sometimes be tricky but rre has a good write up.
you will also want to gasket match the intake manifold. just swapping the tb alone wont net you much of a difference unless the intake mani is opened up also.
Yes, the 2g intake manifold inlet needs to be ported to match that of a 1g TB. And the TPS needs to be moved from your 2g TB to the 1g.
Yes, TPS uses the same color codes so you can splice in the 91/94 TPS harness.
ISC requires swapping two wires in the harness but is otherwise bolt on compatible.
