1g Thermostat Housing
PokinatchaPunk
328
5
Aug 9, 2002
Fort Walton Beach, Florida
Ok real simple....can anyone post up a CLEAR pic (trust me I spent a good hour looking for a clear pic in the gallery) of the routing of the hoses from the front of the 1g Thermostat Housing. It would be so f'in helpful right now!!!
That would be great if he was looking for the vacuum lines but he's asking for the routing of the coolant lines on the thermostat housing.
Is this what your looking for?
Steve
steve that's perfect only small problem is that I have a different style housing I guess I have two pipe coming out in front. One should be running to the turbo and the other I'll have to block off. *Using an external oil cooler* Just trying to figure out which pipe is which
Heres the pic..... There are the two smaller pipe coming from the thermostat housing. One goes to the turbo and one goes to the oil filter housing. Which is which
Circle or Square Goes to the turbo?
I just went out and looked and it seems like the upper circled one goes to the turbo and the lower square one to the oil cooler.
I have manifold heatshields so it's a little difficult to see the turbo water pipe to be 100% sure.
Steve
Hold on, pictures coming.
*edit*
This one...
Goes here...
The lower piece runs behind the turbo from what I can see.
I expect rep points for doing this is 12 degree weather :)
What is different? It should be the same thing. The one shown in my 1st pic is the one you circled.
Here is a picture with the radiator hose off. Never mind the writing. It's from an old thread.
