1g swap..missing pieces..
GSXtacy98
36
Mar 14, 2003
Fairfax, Virginia
So i'm swapping a 6 bolt finally, however there is a few pieces I am not readily able to come across...
6 bolt rear main seal
6 bolt front crank seal
Does anyone know where I can pick these up at a reasonable price?
Also, will I be needing a 1g throttle body and oil pump or alternator?..they are not on the list but I am not sure if the 2g ones bolt up...
Brad
You'll be fine with a 2g tb.
Brad
Use the 2g alternator. The 2g t. body will also work. Im not sure on the oil pumps, I used a 6 bolt pump on my 6 bolt engine.
just order a new front cover for a 6 bolt it will have new oil pump and the front crank seal. on the rear main seal do you need the piece that bolts up to the block that holds the seal or just the seal? 6 bolt and 7 bolt rear mains are different from one anothe in design wise but not in bolt pattern wise at least in my case they weren't (90 6 bolt in 93 that had 7 bolt)
what intake will you be using? the 1g tb is bigger than the 2g but you have to make sure you get the 91+ for the correct configuration. if you are using the 2g intake manifold you'll also have to port it out to match the 1g tb size. i used the 1g tb and the 2g tb elbow since it's larger than the 1g. by the way...the 7 bolt configuration began in 94, not 93.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
