1G Stray wire help!
LocknessMonster
113
Jun 19, 2007
Saint James, New York
My car is ready to be cranked over for the first time but I have a couple of stray wires that I cant figure out where they go. The first bunch are located by the alt. The two bigger wires with an eyelet on them, do they go to pos or neg stud on the alt? The other ones go into the t-stat housing sensors, a total of five wires. Thanks for your help guys.
The alternator harness: the two white ones with the eyelet go on the terminal next to the plug for the alternator. The rest have to do with the oil pressure sending/oil dummy light.
As for your T-stat harness, two of those are for the ECU temp sensor. Its a T shaped plug. The top part of the T is the green/blue wire and the vertical spade is one of the yellow/green wires. The other yellow/green is for the single spade connector for the dash gauge. As for the other ones, I can't remember. Try this link:
http://www.ecanfix.com/users/manualcd/gift/dsm/1g_circuit_diagram.pdf
