1g Alternator B wire help
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
Guys Im new to the 1g world and was wondering where does the B wire go 12v , on the stud sticking out near the bottom where the long bolt goes thru ?
or in front near the rad where I can screw a bolt in?
Does it need a plastic washer? if I dont put it what will happen ?
The B+ stud comes off the regulator and is insulated from the case. The wire from the fuse box fits over the stud and a nut holds it.
While this VFAQ is for the 120A alternator used of the 3000GT is give you an idea of what's inside a typical Mitsubishi alternator.
Stealth 316 - Alternator Rebuild 1991-1995 3S DOHC
