panamarojo
- 178
- 0
- Sep 8, 2008
KLAMATH FALLS,
Oregon
1g, awd with 550's and 2g maf. 3" cat back. 190 walbro. MMCd palm pilot and s-afc.
So from what I have read, ill have to let my car warm up in idle and check my fuel trims. This would be the ft low? so if its reading 89% (rich)? I should bring the afc, low throttle, 1000 rpms down to -3 or so to lean it out? this will bring my fuel trim on data logger up to 100%? and so on for the other rpms up to 4k rpm? will 3-4k show up on ftmedium on palm? Also how long does it take for the palm to register the corrections made on the afc? When I free rev to 2k rpm, how long till the fuel trims change on the logger?
Then move my low fuel trims to my high and start tuning for knock. How do you know if its a lean or rich knock? by the o2 voltage? above .95 is rich?
So I got the 1k rpm low throttle closer to 100%. But I noticed when I free rev it to 2k, the ftlow got to about 118% and ftmed goes 113%. Which one should I pay attention to? And Is that normal with 550's and 2g maf? 118% would be on the leaner side correct?
Could I send anyone my data log so they could make sure it looks correct?
