1G 1g popup headlight door problem
cfeyhris
32
Oct 23, 2008
syracuse, New York
ive tried to search and ive really came up with no common answer.
i bought a 91 eclipse yesterday with a bunch of bent valves. took the head off and when i was going through everything electrical, the headlight doors wont open, ive checked fuse-able links, fuses, motor connections.
i even tried to jump the switch on the dash and nothing.
anyone have any ideas?
Check the motors to see if they are getting power. Check different spots in the circuit to see if there is power running all the way to motors. If there is power getting all the way to the motors then it could be bad.
Okay, trace the circuit back from the motors until you find power. Between where the power is and the last place you checked with no power is where you will find the problem.
