mjm0157
- 42
- 27
- Dec 16, 2008
easthampton,
Connecticut
I was going to install S90 throttle body but after reading bad reviews and seeing pics of how they were built, I decided to go another route.
Antique 1g throttle bodies sell for a premium these days so Here is what I did.
I took a less sought after 1G Non turbo 60mm Throttle body and modified it to hook up via vband clamp. From what I have seen you can also use a 3000gt throttle body.
Here is it mocked up, I cut a bit off the TB
Welded up the piping
No more elbow gaskets!!
Wanted to eliminate vac leaks so made this set up fool proof. FIAV and IAC are blocked off on bottom of throttle body. IAC was remoted using R,venge performsnce IAC block (magnus one is disco)
Pressed in heavy duty seals. Shmeared Ultra grey RTV on outside of seals
Only down side to this set up was having to use studs instead of bolts. I used stainless studs. I added permatex seal & lock on threads to stop any vac leaks on throttle body bolt threads.
Material list
1g NT throttle body
Heavy duty throttle body seals
Ultra grey RTV
2.5 in Mishimoto vband clamp
M8 x 1.25 x 80mm stainless studs - Amazon
M8 x 1.25 nuts
1g throttle body to intake manifold gasket
Permatex seal & lock
FIAV blockoff plate
Extras welded in bungs for IAC, GM at, water meth, BOV flange
Material list
1g NT throttle body
Ultra grey RTV
M8 x 1.25 nuts
FIAV blockoff plate
