1G NA intake cam
Lone
30
Feb 23, 2011
Nampa, Idaho
For a 91 non-turbo with 5sp, I need to replace the intake cam and I am wondering what other intake cams I can use from other years or models. Thanks
If its from a 4g63 motor it will work
--1990-1992 turbo 5speed cams: 244 ex, 252 in
--1990-1994 turbo auto: 244 ex, 244 in
--1990-1994 n/t: 244 ex, 252 in; intake cam is advanced about 5 degrees vs. the 1990-1992 turbo 5speed, 1993-1994 turbo manual and 1995-1999
--1993-1994turbo 5pseed: 252 ex, 252 in; the intake cams have .05ish more total lift than all the other intake cams but the exhaust cam has the same lift as 1995-1999 cams
--1995-1999 all trannies: 252 ex, 252 in; same peak lift on both sides as 1990-1992 turbo 5speed, and all auto & n/t cams
Thanks for the reply.
If I replaced it with a Turbo cam would I need to swap the CAS as well?
I found 95 96 cam shafts for cheap, but not so sure how they would work out. Anyone have any thoughts on performance or usability changes?
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
