1G 1G 4G63 NA not starting?
arbour
Jun 24, 2010
Regina, SK, Canada
so the day before i drove the car all day without a problem.. i went to start it the other night it would crank over but not start at all.. im so baffled.. i have fuel in my tank. i checked the 3 fuse boxes under the hood nothing was visibly blown. i have a 92 eagle talon 2 ltr non turbo front wheel drive, lsd tranny. manuel. all help and tips are welcome!
do you smell fuel whe the engine is cranking. if not look further into your fuel pump. make sure you have spark, connections at coil, power transistor. make sure you battery negative is tighly secured at the battery and body.
