1g Motor, 2g tranny
Spyder4g64 said:
when using a 1g motor and a 2g tranny, what clutch do u use? I kno i have to use a 6bolt flywheel, but what clutch, a 1g or a 2g? Thnx...
Will the motor mounts line up? The only 2g I worked on had 3 of the mounts on the tranny where as all the 1g's I did had them on the block?
Just wondering though.
Mike
(the 2g was a '95 if it makes a difference)
There will only be one bolt hole that won't be used. As long as the dowel pins are lined up and you have a couple 3 of the 4 bolts in it will be fine. As far as the clutch goes used the order a clutch for a 1g.
Like I said , I only worked on one 2g, so I was not sure.Thanks for clearing that up.
Mike
