CrackedDSM
- 5,833
- 5,730
- Dec 17, 2009
Pensacola,
Florida
Sup fellas. Me again back with another problem.
Symptoms: Transmission will not disengage the clutch. If you try to start it in gear, car lurches forwards. When the engine is running, if you press the clutch in and try to put it in gear, it will not budge. Linkage is adjusted properly, trans goes into gear perfect when engine is off. Transmission has like 0 miles on it.
More info: I have not bled the slave yet, but I sat under the car and had my wife push the clutch pedal in, and the clutch fork does move/does push against the clutch plate like it SHOULD work. I'm not sure exactly how far the fork should be pushed by the slave. Is there a hard number/measurement it's suppose to move? Clutch fork is right in the middle of the window, if a little bit towards the passenger side if anything.
QUESTION:
Is this sound with the engine on related? It's coming from the transmission. IF it is related, what could be making this sound? As far as I know, the transmission has redline shockproof fluid in it. Manual transmissions are brand new to me, so I have absolutely no experience or clue as to what I'm doing here. I'm an auto guy. Lol. So any help is majorly appreciated!
More info: Noise does NOT go away with clutch pedal pressed.
QUESTION:
