LA_gst
- 44
- 5
- Oct 31, 2022
Los Angeles,
California
Hey everyone,
Finally got my car back up and running (sort of). The mechanic installed a 1G intake manifold along with a 1G throttle body, but everything else remained from the 2G setup, including:
2G EGR system
2G Idle Air Control Valve (IAC/ISC) (brought over from the 2G throttle body)
2G Throttle Position Sensor (TPS)
2G MAP sensor
2G vacuum lines & solenoids
2G fuel rail & injectors
2G coil pack & ignition system
Stock MAF & intake system
All original 1G gaskets used for the manifold & TB
Now, I’m dealing with an unstable idle. The throttle body adjustment screw is practically closed, and the TPS was rotated back and forth to get the best possible idle. But it's still not quite right.
This is the start of the car after adjusting it.. It idles harsh but then idles normally after it warms up for a while. But then after you drive it it goes back to the rich idleing
2G EGR system
2G MAP sensor
