Resolved 1G Injector Connectors/Clips
GSXlaunch
392
Sep 3, 2003
Just wondering where I can get some injector connectors/clips. I pulled some off some 1G non-turbo cars at the salvage yard only to find out the wire coloring is different then what was on the injector connectors on my car. What do you guys suggest? I have two connectors that are cracked and are missing the clips. Thanks for the quick help.
Do yourself a favor and get rid of those. Go buy some 2G clips off any 2G, any neon, whatever. Pull your harness and splice them. All 4 clips will have 1 wire that's same color. That is common ground. I did it to my car, and now it's 10x easier to remove those injector clips. Just squeeze and pull. No more of those damn cracked clips, missing metal clips, etc.
BTW, I think I gave the guy $5 for all 4 clips. The injector clips on the 2G and neon should have a harness that you can undo to get it all out in one shot.
Cool, thanks. I think I will order the ones from DSM. Any ideas on how I can keep that connector from coming loose until the other's come in? Thanks again.
