* * 1g Help Please !!!
TonyM2487
Nov 13, 2006
Milford, Connecticut
Hey everyone i really need some help with my 91 1g talon i have had talons b4 and have never had problems like this but this one i just cant fingure out. A little about the car it is a 91 talon that i have put a 90 gsx motor in it and has had a redone head, also the car has a stock motor with a 16g turbo, injectors, FPR, boost controller, full 2.5 inch exhaust and safc and a few other little things. So my problem is that i cannot get the car to idle it will start up fine and shut rite off. Some of the things i have tried is, Changed the cam sensor, i have tried 3 or 4 different MAF sensors including the gm mass translator and sensor, i have tried the stock ecu and the ecu from the 90 gsx where the motor came from. Also i have tried to mess with the safc,,,i was able to get it to idle once or twice but no where driveable and it ran super rich i have also tried logging it with mmcd and the car doesnt pull any codes which doesnt make any since and it seem that nothing i do makes any kind of differece i have talked to a few different ppl and no one can really give me a clear idea of where my problem is so i came here in hope to find an answer...If someone can help me out that wud be great i really want to get this thing on the road i have been working on it for some time now and just cant get it going PLEASE HELP !!!! :confused::confused::confused:
Did you switch those wires around for the ecu. Between 90 and 91 they changed two wires around and that could be your problem.
Well i have not done the boost leak test because i dont have an air compressor where the car is nor do i have the boost leak fitting but i will defently be getting it this weekend and once i test it ill let you all no what i get,,,thank you for all the help this far
