1G head swap
BurrowZ
836
5
Nov 28, 2010
Duluth, Minnesota
Alright so I am in the process of swapping a 1G head onto my 97. Reason I am doing this is because so many exhaust studs were broken in the old head I just gave up. So I bought a new head for it, but after looking closer found out it was for a 1G.
So I have the intake manifold and TB, IM gasket, OEM composite head gasket, TB gaskets, and exhaust manifold gasket ready to go. I am just waiting on the 1G water pipe and T-stat housing to start bolting it together.
My question is, since I am halfway done and the head is off, what should I change/upgrade while I am here?
I don't want to drop my oil pan being I have an AWD and this is being done in my little garage. I have a new timing belt, balance shaft belt, accessory belts, and pulleys etc. Also have a new fuel filter but that is proving to be tough to break loose.
Any info is helpful, and if it matters the motor has 91k on it.
The mods in my profile are up to date, or at least will be when this swap is done
fuel filter is alot easier to do if you can drop the transmission, when you ask what other things people should suggest you should tell us your goal with the car: is it a daily driver, are you going for a certain power number, and with all of that what is your price range?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
