Resolved 1G FWD axles in an AWD?
Eagle 5
380
3
Jan 26, 2003
Cincinnati, Ohio
Will the FWD axles work on the front for an AWD or are they completely different?
They are different. I have swapped mine out with the AWD tranny and axles in my GS-T.
The right driveshaft will work, but the left one will not, because it's a straight axle. AWD has a two-stage axle (normal drive shaft + intermediate shaft.) From what I've seen working underneath, if it did not have this system, it'd never clear the transfer case. So, the only worthwhile thing you can rip off a FWD is the passenger's side front.
Putting FWD axles on a AWD car is going backwards. You would no longer have equal length axles. The also wont fit into a AWD trans.
(I've personally tried to put AWD front axles on a FWD trans on a 2g and they're a different diameter)
