1g driveshaft clunking
DSMITHGSX
33
Nov 16, 2008
williamsburg, Pennsylvania
hey guyes after my project i decided i would fix my driveshaft to.. i put to knew carrier bearings and and a new u joint put in all back together got it on and i went 15mph and dang thing is clunking up and down by the rear carrier bearing... the bolts were tight did i do somthing wrong with the joint(with the 6 balls in it while putting abck together did any one ever have this prob.. if u dont understand ask..
yea man they were tight would a 2g drive shaft work on a 1g
could it be the t case fluid just thought of that when i removed the t case when i pulled my motor out i didnt think fluid could come out of it so i didnt put no fluid it in
If you left the drive shaft in it then is wouldn't have leak out, I supposedly put a 2g drive shaft in my car, I have a good 1g driveshaft just LMK
yea it came with the rubber boot...and i took the shaft out of the t case i didnt drain it tho so is there still fluid in my t case ill have to look
heres the ? guyes will a 2g driveshaft bolt right up to my 1g gsx
