1G 1G Crossmember Studs
Mitsu82330
51
May 8, 2007
Beaverton, Oregon
My questions is regarding the factory studs coming from the chassis that the front crossmember slides up onto to attach the crossmember to the car. You can see the ones I'm referring to in the attached picture (not my pic, found it in another thread) which has one of the studs circled in red. Should these studs be loose in the chassis or should they be fixed in their position? Currently my studs actually feel like bolts that are loose in the chassis and can be pressed up into the chassis and I'm wondering if this is normal? I don't remember the studs being loose on my last DSM, but until just recently it had been a while since I removed the front crossmember, so maybe I'm wrong.WTF
