turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
Well, a while back i blew a HG on my way to sioux city to hang with a friend, and while in a friend of his garage having my car fixed the owner of said garage decided to "help" I hadn't beat the car much since then and noticed strange rnning issues when i did... poppinjg/backfiring under WOT and just not feeling right but running well either way, albeit rough and inconsistant on the tune)
I won't even go into how he destroyed my tensioner and i had to rig the timing belt tight to drive home but rather focus on the running issues after the fix
I've always taken the easy way out and just ran batch fire injection on my 6 bolt with a black top CAS and with many deleted OEM pieces and my EMS having no provision for idle increase while using the AC (unless i gave up one of my "extra function/goodies"
Well, tonight i went through adn did what was needed to go true sequential , i blocked off the smaller 2nd home signal in a green-top CAS by silver soldering a piece of shim stock in it's place, swapped the injectors to where they neede to be to fire in the proper order, set the parameters and went to the store to set the timing since it was past 1AM in my neighborhood
*** a side note.... on batch fire you don't need the "home" or "sync" signals, just the 4 trigger pulses that occur ~75* BTDC and to put the pairs of injectors is the proper places for proepr batch firing which is swapping injectors 2 and 4 becuse 1&2 and 3&4 fire in alternating pairs***
Now on sequential systems that aren't OEM with many emmissions related features built in requiring exact position reference of the cam and crank, the 2nd home only causes trouble because most aftermarket EMS systems only need one home/sync to signal that all 4 have fired and it's time to start again with #1..which is why i had to remove/cover one of the 2 home signals in the green cas ( could have don the black one easier but wanted to tryu the optical for it's lower chance of EMI with having an MSD- DIS-2 right near it... the reason to cover the 2nd home is that anytime it sees a "home/sync" it will go right back to firing injector #1 (and DSM uses a second sync right before teh #3 fire which would throw the whole thing off if left in place)
SO , back on track... the car started beautifully compared to the batch setup, revved really nice off idle, cruised perfect and was down right an improvement ( i mainly wanted these few things plus better economy)
Well whe i was timing the car at the gas station i coudn't find the timing mark to save me, tried both wires 1 and 4, so then i try wire #3 and viola! timing marks!!!
Now i had put the green cas in exactly as the black top had come out, but either they are different or the "helper in sioux city" had boogered that up too on install ( i had passsed out at about 4am and he decided to "fix it for me when i was sleeping"
Now due to many reasons that are stated on this forum the car can and will run with teh CAS 180* out with most ECU's other than stock 2g stuff
So tomorow i set teh CAS back in correctly and start playing with ijector phasing, but i must say that either way the stalling with teh AC on when stopping, bucking at low throttle cruise sometimes and random prolonged startign periods seem top already be a thing of the past, ewven with the fuel just puddling behind the valve and firing whe it gets a chance it's been running better tonight than it has since the HG went a couple months ago (but i've been too sick to really drive/test it anyway untill the last 2 weeks)
So, even at 180* out the car is running harder, cleaner and idling a thousand times better on 1000cc injectors and e85 (and i had it pretty good to start with )
I will post my results tomorrow of full on testing and loggin WOT now using full sequential, with the cas in correctly and pull logs with both meth pre-turbo on top opf e85 and a pull or 2 with soe laughing gas (jonesing to hit that button anyway)
But I just wanted to share this becuase these all seam to be common symptoms of a CAS 180* out on an ECU that will still let it run and can so easliy be overlookeed by simply thinking "it just can't be" I hoppe that the WOT backfires and the stalling with AC are teh 2 main things to improve as teh car is still very impressive for the level of build and a fun car to drive and extracting the true benefits of full seq. injection is soemthing i'm looking forward too eagerly
sorry for the TG book, but ya'll kno whow i am
AUTOMERGED EDIT:
Just took my mini-pin to the vet for some shots and got the first true drive while on sequential injection...
Here's what i've noticed
1.) IDLE is unbelieveably smooth and not once did i stall from the A/C compressor kicking in during 40 minutes of driving in light to light traffic
2.)the car is way richer EVERYWHERE and can use a lot of fuel to be pulled out (yey for me as far as MPG's are concerned)
3.) throttle responce is so crisp and even with 1kcc injectors the idle is just like i was back to a stock car with nothing more than the thermal and a K&N
All of these improvements and my CAS is STILL 180* out :
:, can't wait to install it in phase, and i've also yet to even touch the injector phase control map that determines when the end of injection should be accomplished by in degrees BTDC.
4.) the car also now likes to idle at a much leaner AFR (closer to stoich than before when i was running on batch even wehn the CAS was set in correctly)
Untill recently and mainly just for soemthing to do adn for the fuel economy i hadn't bothered to go sequential because most posts on the subject declare that there's really no difference besides the idle stability (due to using one larger pulse instead of 2 smaller ones per cycle where the injectors can't open consistantly) most injectors don't like less than 1.7ms of pulse, 2.3 and above are ideal at idle (given the AFR's can be correct anyway)
As soon as my only employee this year gets back from court and we can get our work finished i will be putting the cas in phase, dial;ing in the AFR's tonight while cruising and pull soem logs..
Oh, and i almost forgot and have no idea why, but spool up is greatly smoothed out and improved
Now i had put the green cas in exactly as the black top had come out, but either they are different or the "helper in sioux city" had boogered that up too on install ( i had passsed out at about 4am and he decided to "fix it for me when i was sleeping"Now due to many reasons that are stated on this forum the car can and will run with teh CAS 180* out with most ECU's other than stock 2g stuff
AUTOMERGED EDIT:
:, can't wait to install it in phase, and i've also yet to even touch the injector phase control map that determines when the end of injection should be accomplished by in degrees BTDC.4.) the car also now likes to idle at a much leaner AFR (closer to stoich than before when i was running on batch even wehn the CAS was set in correctly)
) but at least i can see it to judge where to position the pulley
but the CHRA is PERFECT and so is the turbine.. I ended up losing my intake and airfilter after bouncing face first off a snow drift this winter and didn't realize it for at least a week of driving on salt and gravel covered roads.. lucky i check the oil at each fill up, sadly i drive so little in the winter it took a long time for me to get under the hood and notice this
