1g bov is leaking at 5psi
mhuffman
292
4
Nov 3, 2006
Bowie, Maryland
I pressure tested my intake today b/c the car was running strange... and my 1g uncrushed bov was leaking at 5psi and got worse as i went higher.
Anyone used the forge motorsport BOV? It's a direct bolt on. Are there any other good recirculating 1g bov's that bolt right up?
Bummer... We have two options: you can send the valve to us or I can send you the new lock-ring.
If you have a snap-ring plier or a decent set of needle nose pliers it is a very simple swap. I usually recommend that you try to remove the old ring and if that was easy for you then we can assume that the install will be also... but if not you can send us the unit to complete the job.
Let me know.
I do have a craftsman snap ring pliers. Do you have a pic of what i am removing?
Thanks,
Matt
