1g Block, 2g Head- Cam Angle Sensor Q
rpg_dog
44
Sep 20, 2008
Colorado Spring, Colorado
So I've been searching for hours and it seems that most people put a 1g head on their 2g blocks, but I plan to do the opposite. I want to port match my 1g intake manifold and use the 2g exhaust manifold, and 1g cams, and I know I have to drill the head stud holes an extra mm larger. It seems desireable to keep the 1g cam angle sensor and most of the info describes rewireing the cam angle sensor into a 2g car, if I keep my old sensor is it just a direct swap with no changes to the wiring or mount locations? Is there anything else I'm overlooking to put a 2g heat on my 6 bolt motor?
Thanks
