1G Blacktop CAS in 2G wiring diagram
allturbo
125
Jun 1, 2002
socal, California
I recently swapped in the blacktop CAS for my greentop "long wire" CAS using RREs diagram RRE Instructions
From the diagram you can see that pins 1 through 4 are white, yellow, red, black. I'm trying to trouble shoot and eliminate this wiring discreptancy for the blacktops because the car would not start after installing the new CAS. 1st trouble shoot was to make sure the CAS was not 180 out of phase, but no luck.
Can anyone with a blacktop 1G CAS confirm that the wiring diagram is white, black, red, black for pins 1 through 4. Thanks.
I guess I should rephrase. Is it correct to say that pin 2 (thin black wire) on the blacktop CAS is used interchangeably with the yellow wire in the diagram? Seems like a reasonable assumption, but the car didn't start so I just want to make sure the wiring diagram isn't different for blacktops.
    • george bromwell
    • pma1123
    • Sdcryan1
