Resolved 1G base timing connector?
goonie
251
4
Mar 2, 2004
soutomaior/spain, Europe
Can someone tell me which connector i have to ground to set base timing?
i found a thread that said a yellow with red wire
my harness has two connectors
one is a black wire with white stripe (closest to the battery)
the other is a white wire with black stripe (closest to center of the car)
its been a while that i worked on the car so cant remember which is what?
see pics
car is a 1G 1990 gst
thnx
the (white/black) wire should be for engine speed adjustment
the (black/white) wire is for the fuel pump check
should be a (yellow/black) wire for the ignition timing adjustment
